Rear wiper arm kit
Dec 3, 2009
944
As you may know last year there was heavy snow etc.
My rear wiper arm is slightly bent because of the heavy snow on top of it and broken the cap too. Right now the rear wiper arm slightly sags, which goes off the glass and on to the tailgate.
Prices on a rear wiper arm kit?
Is it easy to fix i.e just replacing the rear wiper arm?
Thanks. :D
nightflight
2,677
13
Sheffield
Prices - ask David @ SERE Motors in the sponsers section.
Replacing - probably, asking the above will tell you what parts you need, this'll tell you how big a job it is
Octane2097
Naturally Aspirated
Jan 20, 2007
792
South Yorkshire
some chavs broke mine off last year i payed less than £30 for it
but i needed a new hub, arm and blade which put the price up a little.
its an easy job 10mins to do yourself
robby71
653
91
Yorkshire, UK
easy to replace, lift up cap and you'll see a 10mm nut (or was it 13mm?), undo this and the arm will pull off, it will probably be corroded onto the spline so you'll need to wiggle it a bit :)
Replace with Polo/ MK5 Golf wiper as it's a lot neater
orange-FR-1994
My wiper arm is fully stuck, I've tried wiggling it but it won't come off any ideas ?
