sean93
I was looking into getting a remap when i came across the BSR PPC 3 Tuning System, a remap you can do via the diagnostics connection instead of messing around under the hood.
The only problem is its expensive and doesn't get the same results as taking it to get a remap professionally. The problem i have is i have lease car, so would personally rather have the option of being able to remove the remap at any time, in case of an issue or when returning the car.
Has anyone had any experience with the BSR PPC 3 Tuning System and do you think it is worth the money or to just get the remap done professionally?
I have been toying with the idea of a dtuk box as well as mine is new it's still well within warranty so want something I can simply unplug. Are they at all traceable? I'd look to remove it a fair few miles before each service etc.
Sent from my SM-G930F using Tapatalk
I have found a device called bluefin, that can be simply applied and removed with a device. I will be purchasing one of these next month. If anyone has any experience with the bluefin remap, would be good to hear?
