Remove Seat badges
lee wwfc
71
Hi, has anyone got a "how to" on removing the front and rear Seat badges as I've tried searching and not found anything? I used a guide off here when I did my mk2 and it was very helpful.
Thanks Lee
Fmxvxx
387
which badges do you mean? the front Seat badge is shaped into the front grill so even removing the badge you'll still see it you'd need to replace the upper grill.
The rear seat badge is the opening mechanism for the boot so again removing not so much of an option.
Any other badges like cupra FR badges etc are stuck on and spraying an adheasive remover leaving that to sit for a few mins then gently heating with a heat gun and then using a nylon trim tool to gently break the glue is the best way I've found to remove them.
lee wwfc
71
Sorry I mean to respray or wrap them and then put them back on
slamka33
300
Just rear badges can be so easily removed. Together with LEON/CUPRA letters on the boot.
Front FR/Cupra badge located next to SEAT badge on the front mesh cannot be just removed, as the shape of the FR/CUPRA logo is on the mesh as well... Pitty...
