Hi, I've started a new thread as my old one about a split breather hose has now gone on to this topic. Here is my current breather system - the suction pump has a small L shaped hose not shown that goes upwards to the intake manifold.
http://i4.photobucket.com/albums/y127/patb303/PCV/IMG_0255.jpg
Here is the breather hose kit I have bought - you can see that the suction pump and brake booster line are gone.
http://i1057.photobucket.com/albums/t399/Clear_Action/20032012237.jpg
Finally here is a thread where some people have done away with the suction pump (as it is prone to both boost and vacuum leaks) and brake booster hose (which installing an oil catch can removes anyway)
http://forums.vwvortex.com/showthre...come-take-a-look.-suction-jet-pump-058133753B
So I am thinking of just using my kit to make a direct route from the PCV valve (in the T junction) up to the intake manifold. I think some Golfs were set up like this as standard? As far I can read from the forum link the pump acts as a valve which opens and closes under boost or vacuum and also helps to atomize vapours further. With no brake booster line it's use seems limited and I will be able to get away without it?
If anyone can let me know their opinion would be helpful thanks!
