Replacing ABS Pump
Mar 16, 2008
692
Wiltshire / Bristol
Hi,
My ABS pump has recently decided to go on the blink. After much searching of the internet I have managed to find a refurbished one. My question is how do you fit it? Im guessing that you drain the brake fluid out of the system, unplug and unbolt the pump and ecu, plug the new one back in and then bleed the brake system with new oil? Any help from those of you who have done it or know how would be realy appreciated!!!:D
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
pretty much says it all - i even stripped mine down and cleaned it out first before i did it as it was a used one and still worked :):)
just dont drop it or you'll crack the ecu board in one drop as my brother will vouch for
only thing i didnt do was drain first - left old fluid in the pipes to save time when i flushed it all out after
Mar 1, 2009
1,079
Liverpool
Just thought id post on this thread rather than start a new one.
My ABS pump has given up the ghost aswell... flashed up after a wheelspin.. oops..
Iv VAG commed it and its shown the ABS pump, the lights go off when the engine is turned off, but come b ack on as soon as its supposed to do the ABS self test the next time its driven.
Im just wondering if the ABS pump is the same for all MK3's?
Im looking round breakers online..
Cheers,
Alex.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
the main metal solenoid block is pretty standard but you'll need the number and type off the ecu part to match it up as there are loads different EDS/TCS/ECS etc
thankfully they are pretty widespread
my mk2 one is made from an octavia bottom and a toldeo ecu top
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
always felt different every press no matter how many times i bled it, personally for spongy i would check hoses for bubbles - and check em close!!
i found 2 pipes bloating and it passed mot 20 mins before
May 16, 2008
506
southampton
thats not good mate it passed mot, ill check the hoses i recently changed both front hoses i might get some one to pressure blead the hole system ..
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
must admit in their defence you had to have the wheel off and look right down to see the bubbles mind, no way on earth the mot test would have seen them
May 16, 2008
506
southampton
right a carry on with this problem i took my car into a garage today and a mercanic drove it and came back, and said the reason i got a spongey pedal is because either a abs sensor is dirty and not reading properly, or the abs pump is intermittent and only works some time and when it work i get a good pedal. if its the pump dose any one know how much there are and if there easy to fit...
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
bottom of the abs unit itself so once that's out in open the motor is 2/3 screws and a wiring plug iirc
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
scrappers from £20-£40ish
solenoid block and valves is pretty standard but the ecu part varies with different options abe/eds/tcs etc etc but there is a pretty normal selection throughout vag
for example mine is a mk2 and its running with a skoda octavia block on original pump and a toledo ecu
just a case of matching up the numbers really
May 16, 2008
506
southampton
thats not to bad then just need to get a part number and find one to match it up , but i phoned seat for a price and they said 695 inc vat.. i think ill find my self a second hand one ..
