Jan 3, 2011
574
How much would you guys pay for 4 rs4 fuel injectors?
What do you think the value is?
Also with s3 injectors do you need get the injector rail aswell,
No rail needed, just the injectors.
When I was over in the US picking up my engine mounts the guy at the garage said he had switched his RS4 injectors out of his GTI as he found the S3 injectors performed better.
Look at circa £100 per injector
JKM sell the S3 fuel injectors for £108+VAT each and the RS4 are around the same price new.
I would expect to pay £250-300 for a used set
i appreciate advantages of using bigger injectors.
on an FR whats the minimal requirements to run them ?
absolutley NO NEED for RS4 injectors unless you're running a GT3071r or larger...
Well they were cheap enough, so want that bothered really rarely get s3 injectors pitch up on eBay or forums so they popped up snapped em up quickly,
Are you planning on a big turbo upgrade then? The spray pattern isn't ideal on the RS4 injectors - not bad just not perfect. If you're sticking with the K04 you'll be miles better off leaving the stock injectors in there and possibly upgrading to S3 ones if you can find them cheap enough...
It's an adventual thing to look at bigger turbo I have all the mods ready to fit to car to go straight stage 2+ pretty much have same spec things as you looked at your spec used you and other as a guide have big things for this car!
