Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Your fueling is set by the maf and lambda probes, so it'll make no difference, unless your airflow is greater than the fueling your injectors can provide.
unless it hits its adaption limit John on fueling first surely
lean=melting under boost usually when excessive
EGT's would be very high....................
Cat temp dont know if thats the same thing?
If you see 0.8, 0.9, >1 under boost then its lean as. be carefull.
Mine's trying to achieve 0.805 under boost - surely that's ok?
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
