Seat Leon FR 56 Plate MKII, Injector recall issue
Silent2010
Seat Leon FR 242.8 tdi
Feb 5, 2010
52
Cleveland
My Car is a Seat Leon MKII FR on a 56 plate it has just broken down doing around 55mph
The car just ground to a halt no warnings no error lights just engine cut out.
I hear there is a recall on this model and year for the Injectors and the wire loom can anyone confirm the codes below cover injector issue why the car has been recalled.
I need to know if the codes below are covered by the recall. I have ran vag-com and i get the following error messages.
If not can some one explain the power supply relay for the ECU?
Thank you
Power Supply relay for ECU (J271 OR J363)
P1517 -- 007 -- Electrical Malfunction - intermintantly
Supply voltage for fuel injector Group A
p2147 -- 009 -- short to Ground
Silent2010
Feb 5, 2010
52
Cleveland
Yep Towcester was right the code showed the injectors failed.
Seat replaced all 4 injectors and the wire loom free of charge.
Or and my custom code remap has not been touched.....Happy Days :)
Very please but still very angry they never let me know and I had to break down to fine out.
NOTE: if your car is a 56/57 not sure on other dates then phone Seat UK and get your injectors changed before you too breakdown.......they will check your vin and let you know if it needs the recall.
BenSRG
I don't know how true this is but there are a lot of German cars 2006-2009 that suffer injector/coil/plug issues. I believe different cars shared the same parts (Bosch?).
Driving my E92 down the dual carriageway when it decided to leave an injector stuck open on full, dumping 80 miles worth of petrol directly down the engine.... got her home safely, replaced injector & dumped the oil too for £100 worth of fresh oil and a new filter!
