Seat Leon fr fitting rns510
Pugbug88
Just a quick question I no it's probably been covered before but when u fit this into a car that has bluetooth on the mfd and also iPod dock under the seat will it just plug and play with these or does it need to be coded
mds1256
Facelift Leon Cupra
Jan 7, 2007
1,012
Have just done this to my facelift cupra, fitted the RNS510 and premium bluetooth.
Was a right faff on to get the cable through the carpet to the bluetooth module under the drivers seat. And also the microphone / GPS ariel in the interior light unit.
Bluetooth and RNS510 just plug into existing wiring harness. but will need coding using VAG-COM.
Took me around two hours to fit the whole bluetooth and rns510. All works perfect with funn integration with the display and steering wheel controls
jezyg
2,329
28
With the right firmware it is plug and play your's being Pre Fl you can fit the SEAT OEM RNS510 without any coding.
Pugbug88
So if I purchase 1 off eBay will I just be able to connect it up and everything should work but what do you mean about the firmware which 1 will be ok
Jammy78
422
Hemel Hempstead
You'll need to code the rns 510 to get the directions to come up on the MFD!
Just make sure you get the 2700 fw & v7.1 maps - so you'll get full postcode search & poi!
Also if you get the VW version - you'll need to cut a bit of plastic out of the cage..... very simple job!
What year is your motor? If pre 2008, you'll get the clock shift!
Pugbug88
Mine is 2007 so you only have to code it to get the directions up on mfd but Bt and iPod should not need coding
jezyg
2,329
28
In essence yes the 510 is just an interface so everything that comes up now will still be there just the MFD needs to be told that a Sat Nav is present.
Jammy78
422
Hemel Hempstead
The man is correct!
2007 model......... you'll get the clock shift on the MFD i'm afraid! There's no fix for this!
Pugbug88
How much u reckon a dealer would charge to code it and also how much would u pay for a second hand unit
2007 Leon fr red and black
Newbie to forum
Pugbug88
What do u mean by clock shift
Newbie to forum
Jammy78
422
Hemel Hempstead
Newbie to forum
buy a vcds cable from china £20 & code it yourself!
Version B unit = max £400
Version C = max £475
Search clock shift!
Jun 5, 2008
511
Leeds
When I installed my rns 510 in my Leon a 57 plate everything worked straight away with no coding required at all. The only thing I have to change was the wiring for the aux point but that isn't too hard from reading the wiring diagram on the rns unit. If your unit is a seat one then your clock will be fine too it's only the vw one which will shift your clock. It will take you 5 mins to fit it as it is so easy
Jammy78
422
Hemel Hempstead
Have you got the full MFD? If you have, you need to tick the navigation option via vcds!
Nah, the Seat version will cause the clock shift as well...... it's got nothing to do with what version you have! It all depends when your car was built!
Jun 5, 2008
511
Leeds
Yeah I have the large mfd and bluetooth etc. I didn't code mine in for ages and instantly I got the navigation option through the mfd menu and the directions etc came up when I was using it.
Jammy78
422
Hemel Hempstead
Damn, that was a bit of luck! Your car must have been built when they made the changes as I remember some people getting the seat version & still getting the clock shift issue..... another bit of luck!!!!
Pugbug88
I have got a Leon on a 07 plate would ne1 be able to say if I will have the same luck as speeny (eg is there a certain chassis no)
Jammy78
422
Hemel Hempstead
100% sure you'll have the clock shift issue! All 07 plates have it - the changes came in late 57... a number on the log book will tell you (do a search on here for more info)!
