Serious electrical problem :( :( :(
Mr. Toledo
Hi!
My Toledo has a serious problem...
With the key removed from the car, operating the headlight switch will turn on the ignition!?
With the car started, and the headlight switch turned towards the right, the car will keep running when the key is removed :( the engine turns off, when the switch is turned back to its off-position.
What would cause this? Faulty headlight switch?
Also, openening the drivers side door, does not turn on the interior light. The light does work when key is removed, or when any other door is opened. Is this related to the above?
Besides this, the car drives perfectly with no other problems.
Any help would be appreciated! Thank you :)
