something is seriously wrong with the kiwi
vngtx
ok i have a small list...
1. for the past 3 days ive been getting loud knocks when driving really slowly and turning the steering.
2. ive been getting what i would call clutch "drag". when i change gear the engine revs seem to drop down by 500rpm when clutch is engaged into another gear as if its slipping but only for a second after changing gear. if i boot the car from low revs it doesnt slip :confused:
3. been getting very low mpg. 32/33 mpg on motorway but 28/29 round town??
4. have an oil leak from breather pipe/ cam cover seal but i cant fix it. think i need a new one
vngtx
the knocking noise has gone now :confused: i have a feeling the slip or "drag" could be stretched clutch cable.
F2 Ed
now has VAG com
Nov 5, 2006
919
www.superlite-wheels.com
you're a mechanic, right?
so why the worry?
Why would a mechanic be asking these questions :lol:
as said, thats a common sign of CV joint being faulty
are the revs dropping when the clutch is pressed? Or not pressed?
This could be a few things. AFM, Lambda sensor, air/fuel filters, FPR, ECU, timing etc..
get a new one :)
Oj 89
Senior junior member
Aug 19, 2008
1,707
NW Kent
3. Hate to state the obvious, but try taking your foot off the accelerator once in a while ;) I'm guessing you've checked filters etc, it's not something elementary blocking access from air/fuel sides? No power drop etc?
Edit: Oooh, Lambda. Good idea :p
vngtx
ed its cos i havent had chance to get it on ramps yet and have a look.
Oj 89, do you mean the pedal that make it go?
vngtx
thats whats baffling me, cos its actually slipping now but only at 2500rpm in 1st, 2nd and 3rd gears when accelerating normally, i boot it and it doesnt slip. i have driven many, many cars with clutches on the way out but ive never come across this before. such thing as a warped clutch/flywheel?
vngtx
Definition: Drag
Clutch drag occurs when the disc attached to the clutch pedal continues to spin even after the clutch has been released.
Symptoms:
Clutch drag is usually recognized by difficulty shifting gears. This may or may not be associated with a grinding sound.
Causes:
Causes of clutch drag vary depending on clutch type. Generally, some common causes are problems with binding cables, pedal brackets and the master or slave cylinders.
i know my pedal box has snapped, and since its a cable clutch its either the pedal box or cable right? just need a second opinion before i spend any more money.
