Squeaky passenger window
cupra_mike
861
Hi Guys, ive got a squeaky front passenger window. when i go to put it either up or down its making an awful squeaking noise as if the glass is catching on the rubber seal or something. has anyone else had this issue and if so how was it solved?
MK R BOY
143
Hi Mate
Havent had it on my Leon, but recently had it on my girlies nissan.
You need a PTFE lub spray, wind the window down and spray in the rubber track, not too much and then get something like a cotton bud and run it up and down the track. You need to lub it but not have loads of spray on the window.
Wide the window up and down a few times, maybe redo the lub if u need to but it should be fixed.
Good luck.
cupra_mike
861
any one else having this problem? ive used silicone spray which has made it slightly better but still squeaking. Anymore suggestions?
s_purs
i was going to say about mine at some point, so now is the time!
mine doesnt squeak but when it gets right to the top for the last couple of centermeters it makes some awfual mechanical sound. like a grinding/catching sound. im guessing my motor is dead or something?
is yours an actual squeak or is it like mine?
cupra_mike
861
no not same as yours mate. i wish it was lol. im guessing the rubber tracks are very dry. soon as i try to put the passenger window down its squeaking. (VERY BAD) its the rubber against the glass. its doing my head in
s_purs
i duno which i would prefer. if my motor goes (if thats the thing thats making the sound) im guessing its expensive to fix. i could up with a working squeak lol
BBoy82
Dan the compressor man...
Oct 25, 2008
293
East Northants
Sounds like the regulator guides are FUBAR to me.
Fairly straight forward repair i guess...
Never done it myself, but cant be rocket science surely!!
BBoy82
Oct 25, 2008
293
East Northants
possibly.
Have you tried silicone spray or WD40 on it? If it was just the seals, that would cure it...
Are any scores visible on the glass itself? Birds often chuck moss out of gutters, and if your unlucky it can go down inside.
As for the regulators, I just put "seat leon window regulator" into ebay, and they come up.
Only thing is, theres drivers side only at the mo, so i didnt bother post a link.
Come to think of it, the door seal guide wouldnt show you how to get the glass out either. But from memory of when i had a break in on my old 1.8SE, the glass is only clipped to the regulator at either side with plastic clips, or so the Autoglass bloke said anyway!!
cupra_mike
861
yes ive used silicone spray which has made it beter but not cured. which bit would you spray the sides or inside the bottom where the window is actually going down into the door as well?
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
PITA of a job replacing the window guides, ridiculous design!
Did my passenger one and funnily enough a mates Leon as just chewed up his passenger one too.
