Jan 9, 2008
363
Sandbach
My front end is littered in tiny stone chips, and because I use Super Resin Polish, the white chalky stuff when it dries up is left in all of the stone chips.
Not a good look tbh, what can I use to clean it out? Will something like Lime Prime Lite work?
i'd probably go with a good soaking with APC and a wash down to properly clean the paint then use Lime Prime Light or Lime Prime to remove anything left behind.
Using any of the above will leave you with no protection on the car though (not that SRP has any anyway) so you'll need to put something on to protect the paint afterwards.
If you want to steer clear of white marks, its probably best going for a spray sealant like DoDo's Red Mist or Zaino's Z8
Well my current quick polish + wax is to use SRP followed by Collinite 476.
What could I use to replace the SRP in this process? LIme Prime with a glaze on top and then 476?
Lime Prime Lite topped with the Colli will be fine, Lime Prime and Lime Prime Lite both have glazing oils in them so no need to add another glaze. You'll still want to pay a little attention around the stone chips though to make sure all residue (from both the LPL and the Colli) is all buffed out.
