ok ive fitted a headunit under my steering wheel, by scotch locking the wires off the back of the aircon/seat radio, is this the correct way to do it?
because it works for a bit but then the headunit under the steering wheel just cuts off and wont work.
then after this the seat radio only stops on for 10 seconds if the other headunit is plugged in. i need to remove the headunit to make the seat radio turn on and work
it must be shorting out somewhere?
what have others done? and what can i do?
also what happens if you acidentalty turn on the seat radio and other headunit on at same time?
thanks!
thanks!
