Afternoon all,
My rear driver side brake was sticking, so i had a look at it today. Its on a 55 plate TDI sport 2.0 with bkd engine.
Jacked up took tire off etc. Put bricks in front and behind the three other tires, and handbrake off.
Piston was stuck about half out (pads still have life in them).
Wouldn't budge with a piston winder so i assumed that must have got some crud in the pot itself causing it to stick in place. The dust seal was also not properly sealed at the caliper end, and there was a small rip and the pad end...
Pumped brakes slowly to get piston to come out some more, then managed to use winder to put it back a bit until it loosened up.
Eventually was loose, but because of the state of the cover i bought replacement seal kit. pumped the brakes slowly to get the pot out, lost some brake fluid as expected. (note this was all done while brake line connected to the car!)
New seals came with instructions to soak for 45 min in fluid before installing. So soaked them while i cleaned up around the existing seal and where the dust seal would be reseated.
Put the cylinder seal in, and then put the dust seal over the cylinder, pushing it back away from the pad end. Put the end of the dust seal into opening, then gently pushed the pot into place. Once there was enough space, pushed it further using the winding tool, until it was more then half way in.
Assembled the brake pads and caliper back onto the car.
I bleed that caliper the old fashioned (and maybe wrong way!) - topped up master, left it open - a fair amount of dot 4 went in even though the level was fairly high, as i topped it up, it disappeared into the reservoir. Pumped brake pedal a few times, then opened the nipple. Few spurts of air/dot4. as the pedal went down.
Sealed it up and repeated until just dot4 came out topping up the master a few times in between. The pedal got harder to push in each time as it did when the engine is not running.
Eventually couldn't pump any more, so turned the engine on to soften up the brakes again.
Pumped it a few more times, and turned it off, repeating bleeding again - no air came out just dot4.
Problem i have now is when off, the pedal feels rock solid.
As soon as i turn the car on, the pedal goes hard, then slowly sinks down.
Hand brake is still down at this time. Any ideas what could be causing the slow sink? Wasn't there before i changed the seals...
(i have since read i may have popped the seal on master but hopefully not!)
