Aug 7, 2020
9
Hello, Im new, coming from Bosnia. I just bought Seat Leon, 1.6 EcoMotive, 2010 year. As I bought new tires and changed them for the old ones that were on my car when I bought it, the tyre pressure lamp turned on, as I knew I pressed set for couple of seconds it didn't went off. The tires are balanced, new. The rims stayed the same. I did everything but the lamp didn't turned off... Does anyone know what to do?
does the switch work??
mine stopped working to get it off at the time i used one of the other switches to get it off
had to buy one of ebay
and are you sure your doing it right
dont think its as simple as pressing the button
The switch should be working, the button. I dont know how should I check that. Is it big job to change the button? How much was yourse from eBay?
And yes, I think im doing it right, I watched many videos on YouTube how the rest do it but still no succes.
I had this in a 2007 Leon, I changed the switch and it worked.
I then opened up the old switch and removed a lump of fluff which made that work too :(
very easy to change. trim removal tool
im sure its not hard to check ebay
mine was a few years ago now
