Undertrays On or Off?
Under Trays ON or OFF
  • Under trays ON
    Votes: 24 70.6%
  • Under trays OFF
    Votes: 10 29.4%
  • Total voters
    34
BoostHard
Complete Plonker
Nov 25, 2012
1,391
At Work.......
www.Passionford.com
So,, Who has there under trays fitted still?
I have mine on but I need to take them off so I can get clearance on Bill's rolling road.
Doubt I will bother putting them back on as they are a pain.
Any reason why I shouldn't leave them off?
Interested to hear the number of owners who have removed against those who have kept theirs on.
hyphon12
Daft Member
Jun 7, 2011
1,106
Scottish Borders
I'd put it on if I was you, helps keep crap out the engine bay, prevents any objects being flung up to your engine/box and belts, insulates noise and it improves the underbody aerodynamics (nothing noticable I would of thought but still will).
leon cupra r
Back in an LCR!
Nov 10, 2009
902
Barnsley
They are a royal pain in the arse and make a 30 min oil change so much more work, but they do a good job of keeping things clean in the bay... Especially with all the salt on the roads this time of year it can only be a good thing to leave them on if you can bear the extra hassle.
Edit: Also they tend to hang down a fair bit and are a good warning sign for speed bumps that are getting a little too close for comfort to your sump...
hyphon12
Daft Member
Jun 7, 2011
1,106
Scottish Borders
^ its only an extra couple minutes to remove though? 95% of the cars I service have undertrays and never have issues with them, even heavy duty metal ones.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Always on - to the extent that I've just replaced mine, and with a TDI 150 that's expensive. A previous owner had hit something with it, damaging the tray and sidewall and the pancake pipe, which hangs down very low. The whole back section of the tray had been ripped off and bodged back on with a metal strip.
Mine is a full-length tray and has the additional feature that it cushions the sump when you bottom out on a speed bump. Aerodynamics in and under the engine bay are improved (more airflow through the bay which is kept at low pressure, and the underfloor air flow is smoother) plus keeping water, salt and road dirt out of the bay.
Taking the tray off is not a difficult job,even on axle stands, and must be easy if you've got a pit or a lift.
BigJase88
Jase
Apr 20, 2008
3,765
1,074
I have none lol
Car came with none! All my other vag's i binned them due to running low and its a pita for oil changes
kr1s77
203
Birmingham
i've had my tdi for 3 months and it never came with one. don't know how long its been off. was thinking about getting one to put on tho
ReDBull
Every day's a school day.
Nov 21, 2006
2,991
14
Lincoln
It's on there for aero reasons. All that air that passes under the tray nice and smoothly with it off is going all over the place. Any air that's going up into the engine bay causing your dirty engine is also having a parachute effect. Slowing you down and causing your mpg to drop.
SWANSWAY CUPRA Dealership
