didsi
I Want an LCR!
Aug 25, 2006
123
Hi, a few days ago my engine management light and tc came on while driving. went off after engine off and on. it has happened once or twice in the past but i just assumed it was unimportant seen as nothing wrong driving. I have used vag com and below is the log.
A quick background on car. 75000 miles, 1.6 sx, universal cone filter installed a couple of months ago. serviced three months ago. does feel slightly less powerful but assumed it was due to hot weather.
here is the log file form vag:
VAG-COM Version: Release 311.2-N
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller:
Note: Can't Synch Baud Rate
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0013313
Shop #: WSC 00001
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08 -------------------------------------------------------
Controller: 1M0 820 043 E
Component: 1M-CLIMATRON
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1M0 920 902 A
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 04406
Shop #: WSC 00000
VSSZZZ1MZ4R004813 SEZ7Z0C2089799
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to B+ - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
No fault code found.
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 F
Component: A7 Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 06402
End -------------------------------------------------------
Can anyone shed any light on the codes?! thank you in advance.
Cheers lee, could there be any maf problems judging from the codes? I cant get into engine module, says cant sync baud rate, im searching for solution now, unless you know how to fix it!!!
Ive been looking and may be due to baud rate setting.
I will clear the codes form modules and scan again
ive cleared all the error codes and none of them have come back after a re scan. Thank you for your quick reply
