Various logs, Comments welcome
Phil
Just been out on the A5 doing some logging, comments welcome on the plots. These are for fault finding in the hope I can discover whats causing my low MPG at the moment.
The car is a Jabba remapped Octavia 1.8T which has the K03S turbo
Jonzy
And whats your definition of low mpg? That graph looks to be mbar rather than psi.
Phil
Yep, my mistake - the boost chart should be in bar and not PSI :doh: I diddnt deduct the atmospheric pressure either - do I need to do that?
MAF figures look a little low for a K03s, my Stage 2 Ibiza on a K03 is pulling 160s on a standard airbox and dirty paper filter but that wouldnt account for low mpg.
Boost seems ok, looks like quite a conservative map peaking at 17psi and holding to around 11. Charge temps also seem fine.
Can you log your o2 sensors please? Blocks 32/33 (i think)
SWANSWAY CUPRA Dealership
