Veggie oil conversion on a PD anyone?
  • Thread starter mashpotato_1981
  • Start date
mashpotato_1981
Just a quick thread to see if anyone running a pd engine has had a veggie oil conversion done? Had any problems? Done on any re-mapped cars? I see smartveg have done some on the pd engine, £350-400 fitted.
For the purists, I know what you thinking why do I want to even consider it??! Not saying it is right but simply I would be saving 1k a year on fuel which can go on mods elsewhere...:clap:
Therefore, surely it is worth considering...??
Thoughts pls peeps...
enigma
109
always thought due to the high pressure injectors used on a PD engine they couldnt be run on veg oil as it messed them up due to them getting all clogged up or something similar :confused:
James_R
5,653
70
37
Manchester
The problem is that the nozzles will become blocked due to the thicker sticker fuel. Its been well noted that even running bio-fuel thats to far cut will cause problems with them.
coolypops
Tastes like chicken
Feb 14, 2009
146
The Emerald Isle
Running veg oil has also been blamed for causing turbo vanes to stick = costly strip and clean.
I don't see how this could be as the vast majority of people with this problem aren't running veg. oil.
It's just due to soot buildup from the car being driven economically and never being given a good blast out.
But, as stated above, veg oil in a PD is always going to be a bad idea...
Speaking to techies in a SEAT workshop in Spain, where veggie conversions and bio-derv is much more common... Veg oil contains "stickier" compounds that increase likelyhood of clogging up. Just quoting what I was told is all. I had to have the turbo stripped and cleaned out on my 130PD - and never used veg oil - but do use a range of diesel in France / Spain much of which contains higher bio content.
BTW my 130PD got mucho blasting out, esp when towing 1000kg of caravan...
coolypops
Tastes like chicken
Feb 14, 2009
146
The Emerald Isle
Although the two fuels may be different (ie. stickier, more corrossive) the gases and particles created by their ignition are the exact same, just in different quantities.
So maby there's more soot from bio diesel or the particles are larger or something... (where's a scientist when you need one? :D)
That's unfortunate about your turbo but most of the time they only clog when being driven softly.
The same reason that short, low RPM drives aren't good for DPFs or cat's.
What mileage were you on when it started sticking?
James_R
5,653
70
37
Manchester
Bio diesel creates oily deposites after the burn (where as none bio tends to be more watery), they may only be minute but it just clogs things up faster.
Duncan FR
im sure ive seen a golf 110 somehwere that has the conversion done. Ive ran old 106 diesels on it and it was fine but they are a much simpler basic engine
iain1970
I ♥ TDI
Apr 19, 2005
484
The Wrong side of the Pennines
IIRC the 1.9 PD is kind of OK with appropriate modification to run on virgin RME bio-diesel, but not ex-chippy stuff.
My 2.0 Altea has a sticker on the fuel flap warning of instant botty rape if I so much as go near a field of sunflowers with the car.
Last year, a firm running an Iveco van on 100% bio fuel had to have three new engines in 12 months during a test. The vehicle was used on short stop-start journeys (parcel work) and the constant heating and cooling of the engine caused the fuel to break the lubricating oil down causing serious failure of components. However, vehicle on longer distance runs fared well.
The jury is still out on the viability of bio-diesel in all guises. The other problem with bio-fuel in general is, ironically, environmental. The crops need to be grown, and this is potentially at the expense of land that should be left alone.
Around 60K and just out of warranty... I posted a thread a few years back - 2007 I think? - about the problem and the dead-end ideas and costs of having the work done at the local stealers. The spanish techies knew what it was straight away and of course it cost me about a quarter of what it would have done in the UK. Top-notch work too; take my current Leon Mk 2 FR TDI into the same shop for any servicing work when I'm over there at the in-laws. :)
