Very stiff drivers door
FR Ste
15
Hi everyone.
The drivers door on my car is extremely stiff to open and close.
Is there anything I can do to the knuckle thing to make it easier to open and close? Or can something be replaced to totally fix it?
Legojon
I only wanted a remap
5,316
2,748
It is faulty or does the hinge just need cleaning and a splatter / spray of lithium grease?
Jimbobcook
6,169
2,551
Also to add to this, have you tried slightly lifting the door as you open it (just using the handle) is it easier then? My brother had an issue with this and it seemed like the door was slightly off somehow... He was tight with money so never got it fixed but lifting the door slightly worked for him lol
Orangieboom
16
Loads of WD 40 and keep moving door for ages just to eliminate the hinge pin being ceased.
jammygit
61
15
Hi guys, did a search and found this. My passenger door basically shuts itself one you put it past the first wheel, but if you gently try and shut the drivers door, there's a lot more resistance and the door pushes itself back open slightly if it doesn't catch on the lock. The door hasn't dropped and have applied the WD-40 lithium grease.
I do have some proper non-stick ceramic grease which i could try. It's meant for brakes but I imagine you can use it on anything.
jammygit
61
15
I used half a can of normal WD-40 blasting away rust / brown crap and then reapplied the lithium grease very thickly and down every joint,
After what is now a few days later, strangely, the door suddenly started working perfectly!! I was convinced that the hinge was worn or something. The lithium grease must take a while to get right down into the crevices.
