Hi has anyone else had a water leak from rear doors seems to be coming in at bottom of door on to plastic sill trim then running down onto carpets. Possibly door seal leaking!
I wonder about the warranty though. If the warranty has expired, and you previously complained about an issue within the warranty period, which they didnt fix, if they would still accept it to be fixed free of charge.
Is it rain water or washer fluid? You could try around the rear washer jet, the washer can leak draining down into the spare wheel well. It's a common fault in the Mk1 Fabia's and i seem to recall some issues there in the mk1 Leons too.
I bought a new 2104 Leon FR with a sunroof from day one the windows kept steaming up and there was a damp smell in the car.Deal said it was all ok.
So one day i looked myself and ended up pouring water from a jug into the sunroof and then i noticed the water pouring out of the head lining and when i looked the drain pipe from the sunroof was not connected.
Took if back to the dealer with my findings and after fighting with seat i ended up getting new carpets unlay and a new head lining.
I have a water leak in the boot, where spare tyre sits.
No idea about the source?!
Any tips?
