Okay mate fancy taking a few pics when you fit your r-tech one? Just the routing of pipe work and how it mounts. Do you keep the air con with that cooler?
Ahh wellycooker �� Ye be careful when I come to order but will more than likely go with r-tech.
See your going stage 2+, you changing your clutch or gonna wait till it goes?
No
problem mate I'll add a load of pics to my readers ride once fitted. I'm having the AC ripped out as I don't use it however if you want to keep it that isn't a
problem.My cooler is having solid pipe work as this will aid in getting the best flow and also eliminate any chance of a boost leak.
I've already changed the clutch to a Helix organic mate so won't have any problems with that.My stock setup failed due to the release bearing giving up once it was stripped down to be honest I could have just changed the bearing and put a new dual mass in as that had signs of wear.
But as I'd already got the uprated kit and it was in bits I decided to fit it anyway.
Going to update my thread in a min so if you write a comment you will be subscribed so any future updates done you'll get an email notification
