Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
The bar is between 18 and 19mm so go for the 19mm ones.
Oh and good luck there a proper biatch
Get a small set of vise grips, these help alot
Thanks for the quick replies!
Willie you made it sound as if it's relatively easy, something I can do on my own?
For £70 i bought the r32 roll bar. So much better than standard!![]()
Was that from the dealer? Thats the 23mm right?
Well I work at Audi and i got it from TPS with a little bit of discountYea its the 23mm with 21mm bushes
Lucky git! lolGot mine off ebay for £40!
And i agree, much better than the standard arb.
Well all I have on my car is the R32 roll bar and i have noticed a considerable difference. I have recently removed my rear seats and parcelshelf to see if that makes much difference to performance/handling. Or am i wasting my time?is the front arb a noticable difference? i was thinking of geting a rear 23mm arb with a front strut brace. will i notice a whole lot more if i get the R32 arb? or will i be fine with my proposed set up?
cheers!
Did you notice much difference with the rear strut brace? I've just got the r32 roll bar and removed rear seats/parcelshelf. Would you do this?I have front and rear strut braces and 23mm FARB and 24mm RARB (adjustable and set on 'hard'), on standard suspension and it handles very well.
Strut braces do make a noticable difference....but no where near as much as ARB's.
will the r32 one fit ok if you have had it lowwered i have gone down 45mm
