Does the FR use the DPF engine code?
If it does then yes, its a Garrett turbo. Model Number: GTB1749VM
Should be a variable vane turbo and i believe the OEM part number for it is: 03G257019 V395
Thats all VAG info though, based off the golf mark 5 TDI GT 170 BHP, which is why im not sure if the FR uses the same engine code as it.
I know when i had to change the turbo on my 140 TDI it shared the same info as the Golf 140 TDI but i knew they both shared the same BKD engine code.
Let me know if its not correct and ill have another crack.
