Can you go any wider? I want as much as I can to make it look more aggressive but as you say, without the wheel rub.CLP do a spacer package which includes the extended bolts and locking bolts if required.
I believe most people run 11mm up front and 12mm on the rear - that sites them fairly square with no rub.
Also, what is CLP chap?CLP do a spacer package which includes the extended bolts and locking bolts if required.
Can
Cheers.
A
Yeah I’m sure I’ve seen that somewhere before. That people run them at 15 and is it 12 on the fronts?I've seen people run 15mm on the rear, but they've mentioned that they do get the odd bit of rub on rough/bumpy roads.
CLP are a VAG and BMW specialist in Sheffield - I use them for fitting parts and servicing, they're about a 100 mile round trip for me; highly recommend them if you're local
That's the one, I'm pretty sure with that spacing the tyres would be more or less sticking out the arches... not my thingYeah I’m sure I’ve seen that somewhere before. That people run them at 15 and is it 12 on the fronts?
Yeah I’m only half hour away from Sheffield. What’s this package they do then?
Cheers.
I've gone with H&R as include locking bolts and I wanted them in Black. They should arrive in the next week I hope.
I've had the 034 Motorsport Dynamic+ Top Mounts fitted to add camber to the front. So gone with 15mm front and 10mm rear.
As per my post I've had the 034 Motorsport Dynamic+ Top Mounts fitted, 20mm would go on with the added camber, just playing it safe with 15mm. Same with rear, 15mm would fit, but 10mm is enough for me.Think you will struggle with 15mm up front tbh, as i run H&R on the Eibach springs and she is very close to the plastic rain guards
the rears you will be fine as i run 10mm no problem
Any photos though?
Do I go for H&R spacers or do I go for the ST Suspnesions spacers?
Are the H&R ones better though?Whichever works out cheapest lol.
Ok chap nice oneEibach, H&R, ST etc. are all the same, you'll just pay extra depending on the brand.
Screw mod? What’s that?Any downside with the 034s, like noise or anything? I have lowering springs and 10mm spacers front and rear but it rubs in front when cornering on track and also once in a while on the road. Also done the screw mod but that didn't help![]()
