Wheel spacers
ryan9
12
Hi guys,
Looking to add some wheel spacers to the standard facelift cupra wheels due to the wheels looking a little lost in the arches now that I have coil overs fitted. What are the go-to spacer sizes that people usually fit?
Ryan
Sent from my ONEPLUS A5010 using Tapatalk
380bhpdaily
1,261
574
You’ll be better off measuring the gap you have on your actual car to make sure they fit and it won’t rub under compression at speed. Google how to measure how to do that and you’ll definitely order the right size.
ryan9
12
Yea cheers mate, just being lazy and checking to see if there's any go-to sizes that work. I come from the BMW scene where spacer sizes are pretty well defined
380bhpdaily
1,261
574
On my Leon I’ve got forge motorsport 15mm front and 20mm rear with the stock 18in 51 offset alloys lowered on koni adjustable shocks -25mm I have no rubbinhg under compression even on track. It really depends how low you’ve got it set on your coilovers mate.
mojo360
16
Reading
Running 15 on fronts and 20 on rear. Might go back down to 10 - 15 as I'm getting rubbing over speed bumps etc
