I'm confused as to what you think you're looking for..... there is no fuse that turns the airbag light off - you have to get it reset by someone with VagCom (or your local, friendly stealer)
They'll usually tell you which airbag is at fault. If the light stays off, you've nothing to worry about. If it comes back on again, you'll need to check plugs, wiring and maybe even the control module or 'bag itself.
