which way do you pull off the gear gaiter?
rasco
199
As Pab's guides are down, I'm struggling to find any confirmation of which way to pull off the gear stick gaiter. Can anyone confirm? The surround moves forwards and backwards a little, do I pull up from the side nearest the dashboard?
Sounds like a stupid question, but I'd like to avoid breaking any clips.
rasco
199
thanks to you both for the replies, but you contradict each other, so now I'm very confused! Will I be able to feel the clips through the gaiter?
nd-photo.nl
4,535
574
The Netherlands
youtube.com
I dont think so (quite deep), I used a large flathead screwdriver. But its quite prone to cracking :(
[edit]
The clips are below the 2nd and 6th gear, does that answer your question ;)
rasco
199
perfect, thanks - so I use a screwdriver basically below gear 4. thanks!
