tstrahonja
541
Well, only problems for me lately...
Ive started hearing whining sound that is not related to turbo, although it sounds like tha and it is not loud, but noticable when it is quiet..
When i drive i can hear it from the front only at speeds from 40-60 kmh..no mater if i am in a gear, on boost, off boost, in neutral so i guess it could be wheel bearing..
Do they whine when they are gone?
Ok, so now my ABS light is lit, ABS not working not TCS.
Can a worn wheel bearing cause this?
When it gets really bad it can, the sensor is propbaly hitting the reluctor ring due to the wear in the bearing.
Oh..so driving it would be dangerous i guess..
So i need a new bearing and probably abs sensor...
dont know if it helps mate but i have a winning noise specially when on smooth roads and it turned out to be my tyres haha soon as i put the tyres on it came aparent and when i took them off and on again you could here the difference.
Hm, maybe...ive tried to "listen" to all bearings at my friends garage but everything seems fine...
