Please could you sort the hyperlink on the main site for 'Forums' so that it opens another tab (or preferably re-uses same tab) rather than opening a new window?
Thank you.
Thank you.
is that not a setting in your webbrowser? to 'reuse windows' or something like that?
Opening into another tab is a browser setting.
I presume the forum link is set to, open a new window rather than using the parent window, i'll take a look,
But the forums are a separate entity to the rest of the site. So we have it so people don't browse away from the main site.
I can see the logic there.
How about a separate button for forum members to return to the forum. Otherwise, it's a bit of a pain to visit the main site.
Don't see the need. When you can open the link in a separate tab.
There is a link back to the main site at the top of the main forum listings anyway.
And at the bottom of every single forum page.
Also while were on the subject, Z, is there any way of making the new posts drop down tap more pocket pc friendly, my pda uses windows mobile 5.0 and cant use the view new posts tabs.
Ok, I'll try again, in case I'm explaining myself badly. (and apologies if it's me!)
I'm in a browsing session with a number of tabs open. (IE7)
One of the tabs is the SCN Forum.
I want to go to the main site, so I follow the link through.
The Main site is now on the tab that the forum was previously on.
I want to return to the forum.
I click forums, and it opens in a new window.
I now have a session open with all the tabs I'm working on. The forum is now on its own in a separate window.
Your problem is IE7
you can go straight to forums without going through the main site though.:
www.seatcupra.net/forums rather than www.seatcupra.net
if you use the forums more than the main site, set your tab, favourites or bookmarks to the first web address and then just click on main site if you then need to go to the main site.
