took my car to a seat dealer to have a clutch master cylinder.
so got that done friday and the receipt said tested ok. come saturday morning the pedal is sticking and im having to pull the pedal up.come saturday night driving down the road and the clutch pedal stuck to the floor and now when i pull it back up and push it back in theres no resistance at all as if its not connected to anything. called out the recovery he tried to bleed it on the roadside and said the fluid is frothing as if there is loads of air in there but couldnt get it done. also found its leaking brake/hydraulic fluid. the master cylinder has a years waranty on it.
if i take it back to the dealer where i got it fitted do you think they will charge me to fix or do it for free because of there fault ?????
