Adding iPod/USB and Bluetooth to Ibiza Headunit
Feb 8, 2011
743
Alex13p,
I've been following all this with interest since I have a 1.2 TSI SE on order and would also like to be able use SD cards or USB sticks. Not wanting Bluetooth or Ipod, paying £340 odd for the factory fit option would be crazy.
Before taking this further I wonder if we can be sure that the head unit in the cars with the factory fit option is actually the same as the ordinary one or is a modified version? If it was the same I'd have thought that USB would be available as a dealer fit option which it isn't. (Presumably the dealer could upgrade any firmware in the head unit is needed).
BTW I notice that Ipod/USB is available without Bluetooth for Fabia and Polo at £145-£155 again as factory fit. These both use Blaupunkt RCD310 or similar and the price makes me suspect that they use a similar system to SEATs.
As an aside can you add files to a multisession CD-RW and have the Ibiza player read them or do you have to start gain with a new or erased CD?
alex13p
∫℮ª↑ ©ч‽Яд
Jan 17, 2011
426
Fleet, Hampshire
Alex13p,
The CD-RW's have to be closed sessions for them to be read in the standard headunits.
Something i just realised today as well is that the headunit can play mp3 cd's - ive only had the car a week :funk:
to find out if your headunit is the same version you need to pull it out and look at the model number. I would have thuoght it would be the same.
Why can't there just be some bloke who is responsible for the design and setup of stereos in SEATS and VAG cars and for him to just come on here and say "Gentlemen and ladies, in order to get what you want you need to get X, Y and Z which can be found by using part numbers 1, 2 and 3 and it will cost £x.xx amount" Job done - pleeaseeeeeee where ever you are - help me :doh:
Stebb
155
23
60
Machynlleth
Hard Drive
On a slightly different tack, I took delivery of a 500GB portable hard drive yesterday for my Ibiza. The drive is powered via the USB socket and is about the size of an iTouch, it comes with a USB cable about 20cm long, cost £39.99 from Amazon.
I connected the drive to my PC and copied my entire music collection to it, which didn't even half fill it! This took around an hour but didn't need any interaction from me once started.
Plugged into the car USB socket I now have access to more music than ever and the browse is sooo fast.
Don't need an iPod cable now, and plenty of space left on the drive!
Note: must be a PORTABLE drive, else you'll need a power supply.
alex13p
∫℮ª↑ ©ч‽Яд
Jan 17, 2011
426
Fleet, Hampshire
have you come to rub it in all of our faces? :ban:
Ninja10R
194
30
Athens, Greece
www.trackbike.gr
Since i'm waiting for delivery of my car, i started looking at the possibilities of adding iPod/USB/Bluetooth also (it's a FR with AUX-IN only).
Quickly dissapointed with my search (the folks in Seat Greece aren't much helpful ), decided to go with a Parrot Mki9200 which offers all of the above and more (SD cards, A2DP Bluetooth etc)
alex13p
∫℮ª↑ ©ч‽Яд
Jan 17, 2011
426
Fleet, Hampshire
Yer but then you have an extra piece of kit making your dash look untidy and the sound quality will be crapppp.
There is a solution out there, it's just not been discovered yet, everytime i have another crack at it i always find something else
*my 100th post on this forum :) *
kareemsafwat
A N I M A L
Feb 21, 2008
137
Egypt
take a closer look at the first paragraph,
"...Listen to your MP3 and WAV files in their car - whether from a USB stick, SD card, iPod or iPhone."
That also why I'm wondering about the iPod, because they don't talk about supporting it in the USB section which probably means it's AUX support?
And yeah that price really is great compared to any other option we've brought up here :)
Just received my car 2day :) finally.
asked for the MDI (6J0 035 342 C) and it will cost 3500 L.E = 350 £
also asked for the paddle shift Bocanegra steering wheel = 3450 L.E= 345 without the AIRBAG :(
well for me the MDI's price is too high, i hope i can find it on ebay cheaper, or may be i will try to buy the ARC's and live with it.
alex13p
∫℮ª↑ ©ч‽Яд
Jan 17, 2011
426
Fleet, Hampshire
http://www.bassjunkies.com/audio/connects2-aadipod003
Look at this!
Says at bottom, Not Compatible with vehicles fitted with MMI .... MMI is the whole thing we need isnt it? SOOOoooo is this saying that if this is fitted already it wont work OR if the option for this is on the stereo then it wont work? If is the first bit then surely this is perfect because it can go into the mmi slot and happy dayS?
Feb 8, 2011
743
Alex13p,
MMI is Audi's fancy control system with big display and joystick to control it. It's not the same as MDI which is what we need.
I though you wanted USB and/or SD card, not IPod?
It's possible the gromaudio device mentioned above would do the job but by the time we've added in delivery and probably VAT too it'll be too expensive for me. I've found out you can buy an aftermarket DAB radio with USB/SD and CD for less than £200 and an FM one for around £130. Only doubt is making the steering column remote controls work.
alex13p
∫℮ª↑ ©ч‽Яд
Jan 17, 2011
426
Fleet, Hampshire
Alex13p,
steering colomn remote has been covered a thousand times, that bit is easy.
Yer i got mixed up between mdi and mmi, f000ing accronyms!
I want usb hard drive functionality really. And a £200 headunit would be rubbish. if i wanted to move away from the standard headunit id want something decent
alex13p
∫℮ª↑ ©ч‽Яд
Jan 17, 2011
426
Fleet, Hampshire
Date: Fri, 18 Feb 2011 14:33:49 -0000
To: Alex
Subject: Re: Website Enquiry - Bartletts SEAT
Hi,
The price of the parts are £208.74.
Bartletts Seat
----- Original Message -----
To: 'Shop Enquiries'
Sent: Tuesday, February 08, 2011 11:26 AM
Subject: RE: Website Enquiry - Bartletts SEAT
Hi,
Thanks for your reply.
I believe the part number is ‘6J0-035-342-B’ or ‘6J0-035-342-C’
I thought it came as standard as well but it’s not on my car. I need to get hold of this part and have my radio activated (using a VAG-COM) to allow this box to work.
Cars without this part have functions disabled on the head unit that aren’t there. When this box is added after build, the radio needs to have the functions activated so It can be used.
To fit the kit properly I would need to have new fascia around the cup holders for the media port to come through and allow access. I don’t need this bit as I will fit it myself into my glove box. Although if you can find the part for this too then I’d appreciate a price please.
If it helps at all, I started a thread on www.seatcupra.net which shows that there are other people who need this solution.
http://www.seatcupra.net/forums/showthread.php?t=303785
Many thanks for your help
Alex
Sent: 08 February 2011 11:08
To: Alex
Hi there,
Sorry we do not completely understand your question. Does the car not have factory fitted the USB/AUX connector under the radio?
I believe this to be standard build on 2010 Ibiza Cupra's.
Many Thanks
Bartletts seat
To: Bartletts SEAT Enquiry
Sent: Monday, January 31, 2011 10:31 PM
Subject: Website Enquiry - Bartletts SEAT
Question / Comments:
I have an exdemo 2010 plate ibiza cupra with no MDI slot for the head unit. (for ipod/usb etc) I need to find the box that sits at the back of the headunit to allow this and then i will take it to a dealership for them to activate it on my headunit. please help me find the part. many thanks
Sent from Bartletts SEAT
Kolobok_4
Are u certain that we'd need to activate the parts with vag-com? Maybe it's plug and play just like the dension units?
Feb 8, 2011
743
Just to confuse matters it turns out that some of the head units are not made by Blaupunkt but by the German firm Technisat:-
www-dot-carcommunications-dot-technisat-dot-com
Front panel looks just the same to me.
They seem to have the required adaptor, but for Ipod only not USB:-
Feb 8, 2011
743
Quote
from that it looks like these are the systems that come with ipod/usb as they list multimedia box under "interface".
I think that just means that it's possible to connect a multimedia box, just like you can connect an AUX device or an active antenna.
I've sent them a message asking about the "Multimedia Mobile Device Interface" they describe on their site and whether or not it will work with their SEAT head unit.
Mind you I don't yet know if the Ibizia I'll be getting soon will have a Blaupunkt or Technisat head unit.
I also wonder if these people make all the recent head units and they are just rebadged Blaupunkt.
Kolobok_4
Quote
maybe, but if you take a look at the other head units (especially the ones that work with their multimedia thing) you'll see that the multimedia box isn't listed in the radio features
