Arru
There are two updates for your device. I can provide you these updates. Please send me a PM.
Regards.
Hola,
Soy nuevo en el foro y no sé muy bien como funciona esto.
Agradecería que me mandara las actualizaciones para H42 y 0319.
Me estoy volviendo loco buscando por internet y no hay manera de encontrar una actualización.
Muchas Gracias.
kevster184
683
29
Have just found this Topic
My headunit is a 'Nav High' Model year MY2015 (just before MY2016)
Has MirrorLink but NOT FullLink
6.5" screen MIB2 with HDD
5F0035020A
Hardware H41
Software 0123
Does this have any updates available?
thanks
I have Nav High MY 2016 with Full Link, Device pt no. same as your one, hardware H42, software 0319, Nav database V0395980122 ECE 2015/2016.
There are updates available, there is a guy on this forum who was selling them on Ebay and I believe the software version went up to 0818 and gave the latest look to the screen layout.
I have only just got the notification for this, don't know why!
This may mean that H42 can be updated to newer software but mine is H41, hardware?
Quiksilver
243
Hi,
I have the multimedia unit -
Device number - 5qa035858
Hardware - H24
Software - 0241
I have both files 0330 & 0346, I copied them to the sandisk 64GB micro SD and the device doesn't see the SW. I tried while the files where in a folder, while the files where in root folder and still didn't work.
Any suggestions?
Thanks.
ysfdncr
176
12
36
New Jersey, USA
Hi,
Hardware - H24
Software - 0241
Any suggestions?
Thanks.
If you downloaded them from internet (I mean public share) I suggest not to install. You may lose functions or brick device. Files maybe corrupted or edited not sure the source of problem.
Quiksilver
243
Let's say that I want to take the chance, how they should be on the SD card? is there a limitation to the SD card?
Stevan
96
Musselburgh
They're not both on there are they? Try the other SD slot?
330 first, then the other. Check back the way on this thread for more info.
Quiksilver
243
I found my error, I tried to do the SW upgrade via regular menu and not long press menu.
Upgraded to 0330, cleared faults and upgraded to 0346, when I tired to verified menu and more the car shutdown due to low battery :( damn it!!
But basically it went good, what will happened if I won't solve the 1555 error?
P.s.
I have the 6.5'' with the MIB2:
Hardware - H24
Software - 0241
Thanks,
Ace.
Reactions: Mike toledo
hunter918
Hey guys,
This is the current version that is installed in mine.
can anyone tell me if there's an update and if so, direct to the download links.
this has become a "mega" thread and it's hard to find it :)
Device part number: 5QA035824
Hardware: H24
Software: 0245
thanks!
Quiksilver
243
Hey guys,
Hardware: H24
Software: 0245
thanks!
yes there is an update, actually there are 2 updates:
1. https://www.youtube.com/watch?v=62YIi73oaj4&t=26s / from 0245 to 0330
2.https://www.youtube.com/watch?v=CnNH5ZrPSOM&t=39s / from 0330 to 0346
That are my videos, they are in Hebrew but all the links and instructions are in English / Spanish.
Enjoy.
paddy6789
1,627
1,080
Preston, Lancs
Enjoy.
Did your Bluetooth, DAB etc work fine after the upgrades?
Seat Leon Cupra 290 DSG Black Edition (Alor Blue)
Performance: Racingline OEM+ Stage Two Mapping | Racingline R600 Intake | Racingline Turbo Inlet Pipe | Racingline Turbo Elbow | Racingline Muffler Delete | OEM NGK Audi RS7 Spark Plugs | 034 Motorsport Dogbone Mount | GFB DV+ | Milltek Large Bore Downpipe | Pipewerx Custom Cat Back Exhaust | Forge Turbo Blanket
Interior: Koonlung K1S Dash Cam with BlackVue Power Magic Pro
Exterior: TRC Front Splitter | Foliatec Exhaust Paint Gloss Black
Quiksilver
243
Everything works fine, but I have the unit without the NAV but AFAIK that should be good as well.
Just see the spanish site for what you need.
hunter918
Enjoy.
Hebrew is my native tongue so no problem there :lol:
BTW, can I update using a DOK or is an SD card a must?
Toda Raba! [B)]
hunter918
One more question, at the end (after the restart) there's a message:
"Start diagnostic tester: Main unit/version comparison,
accepting the error code leads to a restart"
what does it mean and will it always be shown?
10x!
Quiksilver
243
10x!
Don't use DOK, it will cause an error.
ignore it, it won't show up again but you will need to connect via VagCom(VCDS) or OBDeleven to check if you have fault codes (probably fault 1555 which is to approve the SW upgrade)
Sent you a PM.
jshumphries
7
Carlisle
I've searched but can't seem to see if there is an update for my Media System Colour
Part number: 5F0035869C
Hardware version: 851
Software version: 6481
Bluetooth version: D265
If anyone can tell that would be great
Sent from my Nexus 7 using Tapatalk
ysfdncr
176
12
36
New Jersey, USA
You have an entry system which does not support update via sd card. It can be flashed by Odis Engineering tool by using flash files from erwin website.
Kjimi
65
24
Kerava, Finland
Any updates available for my MIB2 Navigation Standard (MIB STD2 ZR +/NAV)?
What is the number of the newest software version ?
My unit and current version details:
Part Number: 5QA035846A
Hardware: H30
Software: 0359
