IMPORTANT ADVICE FOR ALL EXEO OWNERS! Make sure your battery isn't swimming!
Tom B
4,710
16
Northampton
Sorry for the capital letters in the title but this is something you all need to check regularly!
There's lots of talk on Facebook about water ingress and electrical issues on Exeos. If left unattended, the water ingress can cause serious damage to your electrical system, potentially writing it off. The procedure to solve it is pretty simple but it does involve having tools, patience and a couple of hours spare.
The problem is in the scuttle panel/front wiper mechanism/battery area. Open your bonnet and have a look around the battery. If this area is bone dry, you're lucky but you still need to follow the instructions below. If you see water or lots of silt sitting in there, you have a problem.
There are 2 funnel shaped grommets in there that fill up with silt and eventually block up entirely. When they do, the rainwater has nowhere to go so just rises until it finds a place to escape. The ECU lives in that scuttle area on the offside (drivers side in UK) so you can only imagine what will happen if this water starts making contact with the wiring loom or gets past the seals on the ECU cover. The water then gets past the pollen filter seals and fills the nearside front footwell, and that's where the CCM lives. When that happens, the car turns psychotic!
If you've ever owned a 1997-2005 VW Passat, a 1995-2001 Audi A4 or an A6 of similar vintage there's a chance that you'll already be familiar with this one. I bought a 2003 Passat and I had to fix all of the above, as well as a load of corroded wiring connectors. The dash was coming up with a different error every time I turned the key, the locks had a mind of their own, I was denied access to the tailgate and then it wouldn't start. Please don't put this off, have a look!
To fix it, you need to remove all the trims and sealing strips around the scuttle area, move the annoying wiring loom above the battery, remove the battery (make sure you have the radio code before disconnecting!) and look for these grommets. Now here is where opinion divides. Some people say that VAG fit them for a reason and the bottom end is partially closed to stop water from the road getting in there. Other people say that if they were removed, water can exit a lot easier. I'm with the "other people" on this one, so if you agree, you can prise them up, out and into the bin. If you'd rather keep them in, get a thin & straight tool (screwdriver, 3/8 extension, round file) and push it all the way through to dislodge the blockage, pull it out and let the water drain out. Prise the grommets out, put them in a bowl of warm soapy water and only remove them from the bowl when they're totally clean. Clean out all the silt from the scuttle panel, (optional OCD step: apply some sort of waterproof grease to the electrical connector and around the ECU case, Maplin should be able to help with that) and put it all back together.
If you do want to leave the grommets in, I'd recommend making a tool with a metal coathanger that allows you to clear the gunk from the grommet under the battery without having to remove it. Some right angle bends in various places should do the trick :)
If my text version makes no sense, have a look at this Passat B5 guide: http://www.veedoubleu.com/passat/passat-leak/ it's not the same procedure but its very similar.
Good luck!
Reactions: TheJudge2009
Dicko90
78
Good post! You can also clear the one under the battery with out removing it by reaching underneath the scuttle and feeling for the rubber gromet. Once located you can clear the water by poking your finger or screwdriver through the cone shaped bung which should instantly release the standing water I couldn't believe how much drained out when I first did it! I now check this every other week and so far it's never filled up once since clearing it.
Nick
Tom B
4,710
16
Northampton
Thanks Dicko90 & caldi, I'm glad the battery doesn't need to be removed, that should make the process a lot less painful.
I agree with you caldi, if you smell damp you need to walk away. I went to the local auctions a couple of weeks ago and looked at a silver 143 Sport Tech ST. It had no odour but the boot area was so wet that the floorboards were bowing. It's now for sale on a few websites, I hope no-one on here buys it.
Arctic
466
Newcastle...ish
Done this yesterday, I removed the battery to make sure everything was clear.
It amazed me how much water got there, as I had a problem with the TPMS light, hopefully that's the trick to sort it
philster60
7
Hi Chaps
the Engine management light has come on my 2.0 TDI sport tech
why?? its running fine - any advise?
Phil
Dicko90
78
Hi Chaps
Phil
Get a diagnostic machine plugged in as with out a fault code it could be anything! I’ve got a OBD WiFi adapter which I use too monitor the DPF but can also diagnose faults with the correct programme/App. Very handy and only cost a few quid off eBay.
Corvus Cornix
Newbie
Jun 30, 2005
47
Norway
Last year I noticed toe-jam smell in the car. I removed the battey, and yes, water in bottom. Some moisture on top off passenger carpet. First I removed the big plug, diddent sse the smal one. Tried to flush. Then opened the smal one. Everything ok exept the smell. Did by the aerosol can and cleaned the aircon. Sucsess!
This winter I did notice a new smell after a heavy rain period. Checked tha battery bay. Dry. Then on drivers carpet it was swimmin-pool. After some inspection I found out it was the smal drain hole between the bonnet and side panel (up under the hinch) that was blocked. The rainwater was leading back under the ecu area and into the car.
This drain hole is very difficult to spot. BTW, I have a LHD
16566
Tamas328
54
I wish I knew this when I first bought my car. It got flooded and I had to get a new CCM in the end. I was without the car for a few weeks, had to remove passenger seat, pull carpet up, dry the carpet/sound insulation... nightmare.
It's all good now, keeping an eye on it fairly regularly.
The only thing is the remote fob doesn't work with the new CCM, and I can't seem to find anyone nearby with a VCDS cable who could have a go at re-programming it. I should probably take it to a vag specialist
Tamas328
54
Read your handbook, it will tell you how to match the fob, VCDS is not needed.
I tried the common ways when you put a key in the ignition and lock and unlock the door with the other key 3 times (and various versions of the above as found on Audi forums). I think it only works when you replace the battery and the key needs "reminding". But this key has never been paired to this CCM before so it is different.
Tamas328
54
I bought a fob and matched it to my Exeo, I have VCDS but I did not have to use it, try this
Follow these simple instructions -
You will need BOTH remote key fobs to reprogram one or both of them.
1. Take the key you DO NOT want to reprogram and put it in the ignition.
2. Turn the ignition on but DO NOT start the engine.
3. Put the second key in the drivers door lock. Whilst it is in the lock press the UNLOCK button once only (the lights should flash on the car but the doors will remain locked).
4. With the second key still in the drivers door lock, unlock and then lock the door again.
5. Remove the key from the door lock.
6. Open the car and remove the key from the ignition.
7. Now test the key that you have reprogrammed, the one you have removed from the door lock.
If both your remotes don't work, do all of the above for the first key, but at step number 3. press the UNLOCK button TWICE. The light will flash twice and then proceed onto step 4 and finish the procedure.
My spare key is a service key so no remote buttons. Will it still work?
Tamas328
54
Also, if when I open the door (key in lock and turn as buttons don't work obv) I have about 10 seconds to put the key in the ignition before the alarm goes off.
Tom B
4,710
16
Northampton
This is the remote coding procedure from Ross Tech Wiki, it might help you Tamas328
Remote Control Synchronization
The 8E/8H platform Audi A4 is noted for losing remote control synchronization after low voltage conditions as explained in several TSBs. If the remotes are not functional after performing the Remote Control Matching the following synchronization may be necessary:
Press any button on remote control.
If vehicle does not respond by locking or unlocking:
Lock and unlock vehicle within 30 seconds using driver-side lock with the door closed.
Open the door and insert the key in the ignition turning it to the On position.
Remove the key from the ignition.
Now check function of synchronized remote control.
Tamas328
54
Checking the posts, if you do not have a remote that has been programed to that CCM in the past you will not be able to program your remote without VCDS or similar/dealers. I have programed a new remote before but only with a working remote. The last post is only for re-programming previously matched remotes after voltage loss.
Yes thats exactly what i thought. Been trying to find someone in the VCDS facebook group but nobody seems to be around me in the north east.
Tamas328
54
There is a second bung! Do you guys remove both?
There has been quite a bit of rain recently (we are up in the north east) and I had a quick look at the battery tray swimming pool situation.
Of course there was about an inch and a half of water in there so I removed the battery and took the bung out, but while I was there I realized that there is another rubber bung towards the centre of the car. I left that one in place as I guess it can no longer flood the car but just wanted to check what other people have done with it.
Tom B
4,710
16
Northampton
Yep, remove that one too. It's got a cable through the middle of it so push it down as far as you can with a big screwdriver.
marculos
116
7
I removed a large bung just under the battery., Pushed it down with large screwdriver and pulled it out from underneath.
formby1
Paisley
I have suffered from water getting in to the passenger footwell. first noticed it in april this year when the back passenger footwell was sodden. I had carried out all the suggested checks, removed the bung under the scuttle, removed the pollen filter and silicone sealed around the housing. I even removed the large 4 " bung on the bulkhead and silicon sealed that as well ( it was a right Bu££er to get back in ). I dried the carpet and put newspaper under to help dry out. the dry summer really helped and i thought that was that. 3 weeks ago the catch on the glove box snapped and so i had to remove the glovebox. thought I would peel back the carpet again 'just to check' it was soaking again. after a lot of swearing and checking every thing as before, i put a hose in the scuttle area- no sign of water build up nor any water getting into cabin. put the hose to the right of the pollen housing- ( looking from the bonnet of the car) again no sign of water ingress.
Put the hose to the left of the pollen filter and there was water dripping into the cabin from somewhere above the front footwell.
looked around the pollen filter for any sign of where it could be getting in and i noticed a different coloured area Pic 1 on the bulkhead to the left of the pollen filter housing.
put my fingernail behind it and it was loose. pulled it back and lo and behold there was a bolthole pic 2 that was sucking the water straight into the cabin. Sealed it with thread tape and a bolt pic 3.
Hopefully that is that. i have used a dehumidifier for three 6 hrs sessions with the carpet raised as far as possible, so hopefully that is it dried out.
only problem now is the airbag light is on because i turned the ignition on when the glove box was removed
