Monday,29,May,2017,16:57:12:21489
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: VSSZZZ5FZER134694 License Plate:
Chassis Type: 5F (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F A9
VIN: VSSZZZ5FZER134694 Mileage: 30005km-18644miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CUPA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 EL HW: 04L 907 309 D
Component: R4 2,0L EDC H22 7542
Revision: 83H22---
Coding: 01190012032501080000
Shop #: WSC 00049 770 00244
ASAM Dataset: EV_ECM20TDI01104L906021EL 002008
ROD: EV_ECM20TDI01104L906021EL_SK37.rod
VCID: 73E59098DAE6D9D9E4-8026
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 61174000000161
Coding: 18EE8A9234230970007D060941C72918512C9000608294F400610070C003
Shop #: WSC 00049 770 00107
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_033.rod
VCID: 4B952878E296E1194C-801E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5F0 907 044 D HW: 5F0 907 044 D
Component: Climatronic H03 0705
Revision: 00001K07
Coding: 04100104200100011005000000101000
ASAM Dataset: EV_ACClimaBHBVW37X 003017
ROD: EV_ACClimaBHBVW37X_003_VW37.rod
VCID: 275DB4C85EBEE57988-8072
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011412600593
Coding: 0B000A42C20102FB0B244000B10403281000000000000000000000000000
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_012.rod
VCID: 7BF5B8B8F2B69199BC-802E
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5F2 955 119 HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 140407 041 0574
Serial number: 140411165708
Coding: 0BC5FD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y14M05D06H05M05S10S7
Coding: 00885D
Sensor For Anti Theft Alarm System:
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY1406900LZ
Alarm horn:
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000059538942
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 F HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0142
Revision: -------- Serial number: 39331413203616
Coding: 0031051001
ASAM Dataset: EV_EPHVA18AU3700000 002024
ROD: EV_EPHVA18AU3700000_VW37.rod
VCID: 3E7371ACA12444B1DB-806A
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 012 0189
Revision: -------- Serial number: 003P4P95EWH5
Coding: 98CCC000000000005C0000CC008800000065
ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F0D4CA8E6AE8DB990-802A
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 454 001 904 14
Component: SideSensor_Df 008 0887
Serial number: 3576U000000237A0AF0C
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 454 002 204 14
Component: SideSensor_Pf 008 0887
Serial number: 3586U000000580EC6F0Q
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 454 800 904 14
Component: SideSensor_Dr 111 0148
Serial number: 3516R6E685A030000008
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 454 801 104 14
Component: SideSensor_Pr 111 0148
Serial number: 3526R1ADE60030000004
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 454 802 204 14
Component: FrontSensor_D 114 0149
Serial number: 3556V34445A03000000/
Coding: 2D2D2D
