Auto wipers problem/Coding dump needed
HighFlyingBird
2016 Leon FR 1.4 150 in Chilli Red 2019 - 2020
Jan 15, 2019
250
87
Leeds
Hi all
Got a problem with my auto wipers. They come on when rain or water is detected as they should but then they don't go off again. They were working fine but I noticed in carista they were set to disabled, so I set them to enabled and ever since they've not been right, even after changing the setting back.
Would it be possible with anyone with a pre-facelift that has auto lights and wipers to get a coding dump from VCDS/OBDeleven so I can try use it to get my wipers sorted?
az101
87
14
Burnham-on-sea
Did you get the code you needed? If not I can dump mine for you on the weekend 2014 fr St with auto lights and wipers
RUM4MO
7,823
1,000
South Scotland
Remember this sounds like the OP does not have auto or rain sensing wipers, and then enabled them with Carista - now if that trick was tried with VCDS I'd doubt if the new programming would have been accepted, another Carista fail? I have Carista but only keep it handy for read fault codes.
Reactions: Walone
Mr_G
27
8
I read as the OP has / had working auto wipers but noticed that Carista said they were disabled so in a classic case of "if it ain't broke, fix it until it is..." changed the setting to enabled and then discovered they then stayed on despite the rain stopping. The OP has now changed them back to disabled in Carista but the odd behaviour has remained.
Or i could be having a massive reading fail which is just as likely :)
az101
87
14
Burnham-on-sea
This is how I read it too
Big Col
626
89
North Ayrshire
Here's a VCDS scan from my previous car,
2014 Leon SC 184 FR - with auto lights and wipers
mine has a few tweaks but nothing relating to the auto lights or wipers.
Code:
Monday,29,May,2017,16:57:12:21489
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: VSSZZZ5FZER134694   License Plate:
Chassis Type: 5F (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F A9
VIN: VSSZZZ5FZER134694   Mileage: 30005km-18644miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CUPA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EL    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 7542
   Revision: 83H22---
   Coding: 01190012032501080000
   Shop #: WSC 00049 770 00244
   ASAM Dataset: EV_ECM20TDI01104L906021EL 002008
   ROD: EV_ECM20TDI01104L906021EL_SK37.rod
   VCID: 73E59098DAE6D9D9E4-8026
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
   Component: EMB8 EHCB     H31 0356
   Revision: 00000000    Serial number: 61174000000161
   Coding: 18EE8A9234230970007D060941C72918512C9000608294F400610070C003
   Shop #: WSC 00049 770 00107
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033.rod
   VCID: 4B952878E296E1194C-801E
Address 08: Auto HVAC (J255)       Labels: 5G0-907-044.clb
   Part No SW: 5F0 907 044 D    HW: 5F0 907 044 D
   Component: Climatronic   H03 0705
   Revision: 00001K07
   Coding: 04100104200100011005000000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   ROD: EV_ACClimaBHBVW37X_003_VW37.rod
   VCID: 275DB4C85EBEE57988-8072
   Fresh Air Blower Front:
   Refrigerant Pressure And Temperature Sender:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011412600593
   Coding: 0B000A42C20102FB0B244000B10403281000000000000000000000000000
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_BCMCONTI 012001
   ROD: EV_BCMBOSCH_012.rod
   VCID: 7BF5B8B8F2B69199BC-802E
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 5F2 955 119     HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 140407  041 0574
   Serial number:         140411165708
   Coding: 0BC5FD
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547   Labels: 5Q0-955-547.CLB
   Component: RLFS  024 0042
   Serial number: Y14M05D06H05M05S10S7
   Coding: 00885D
   Sensor For Anti Theft Alarm System:
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0315
   Serial number: 000000000ZY1406900LZ
   Alarm horn:
   Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000059538942
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0142
   Revision: --------    Serial number: 39331413203616
   Coding: 0031051001
   ASAM Dataset: EV_EPHVA18AU3700000 002024
   ROD: EV_EPHVA18AU3700000_VW37.rod
   VCID: 3E7371ACA12444B1DB-806A
Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0189
   Revision: --------    Serial number: 003P4P95EWH5
   Coding: 98CCC000000000005C0000CC008800000065
   ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F0D4CA8E6AE8DB990-802A
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 454 001 904 14
   Component: SideSensor_Df  008 0887
   Serial number: 3576U000000237A0AF0C
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 454 002 204 14
   Component: SideSensor_Pf  008 0887
   Serial number: 3586U000000580EC6F0Q
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 454 800 904 14
   Component: SideSensor_Dr  111 0148
   Serial number: 3516R6E685A030000008
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 454 801 104 14
   Component: SideSensor_Pr  111 0148
   Serial number: 3526R1ADE60030000004
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 5 - Part No SW: -----------    HW: 454 802 204 14
   Component: FrontSensor_D  114 0149
   Serial number: 3556V34445A03000000/
   Coding: 2D2D2D
i'll need to spread it over 2 posts, i ran into a 10000 character limit
Big Col
626
89
North Ayrshire
Code:
Address 16: Steering wheel (J527)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 AC    HW: 5Q0 953 549
   Component: Lenks. Modul  007 0070
   Revision: --------    Serial number: 06051404221032
   Coding: 1400
   ASAM Dataset: EV_SMLSKLOMQB 009001
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 77FDA488CE9EB5F9D8-8022
Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb
   Part No SW: 5F0 920 971 H    HW: 5F0 920 971 H
   Component: KOMBI         303 2210
   Coding: 23A409002980260001086A00000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008031
   ROD: EV_DashBoardVDDMQBAB_008_VW26.rod
   VCID: 2F6D5CE8764EBD3940-807A
Address 19: CAN Gateway (J533)       Labels: 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0002020281
   Coding: 030100F40B087300EF0006E8080F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_010.rod
   VCID: 3F8D0CA8A62E4DB9D0-806A
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Component: E221__MFL-PR6  H04 0130
   Serial number: 000000000A0068030414
   Coding: 002000
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Component: J367-BDMHella  H03 8043
   Serial number: 9329343303
Address 42: Door Elect, Driver (J386)       Labels: 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000101389712
   Coding: 00100220DE01040100001000
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 44870344CFC82E618D-8010
Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 P    HW: 5Q0 909 144 P
   Component: EPS_MQB_ZFLS  122 1043
   Coding: 8103
   ASAM Dataset: EV_SteerAssisMQB 010031
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41890A50D0DA3B49A6-8014
Address 52: Door Elect, Pass. (J387)       Labels: 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000101604438
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 43850058CAC62959B4-8016
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Part No SW: 5Q0 907 357     HW: 6R0 907 357 A
   Component: LWR-ECU       005 0080
   Revision: --------    Serial number: --------------
   Coding: 049E000009000000
   ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
   ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
   VCID: 75E1AE80D492C7E9CA-8020
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 5F0 035 858 A    HW: 5F0 035 858 A
   Component: MU-S-ND-ER    040 0425
   Serial number: E5F00705140488
   Coding: 04731001D70A000021111101000800002F0101060100010046
   ASAM Dataset: EV_MUStd6C1PASE 002030
   ROD: EV_MUStd6C1PASE_VW37.rod
   VCID: 2959B2F048AAD3099E-807C
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5F0 919 603 A    HW: 5F0 919 603 A
   Component: ABTmin_Std_Nv  H60 0030
   Serial number: SEZ8Z9PT900BU6
   Data medium:
   Subsystem 2 - Part No SW: 5F0 919 866 F    HW: -----------
   Component:  ECE 2014  --- 0036
   Serial number: --------------------
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 5F0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 140320200139
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X_VW26.rod
   VCID: 6ADB8DFC8D2C181157-803E
End-------------------------(Elapsed Time: 03:55)--------------------------
RUM4MO
7,823
1,000
South Scotland
Clarification from the OP would sort that out, I was just trying to make sure that the OP not offered the coding from the "correct" optioned car, that is all.
Reactions: Walone
HighFlyingBird
Jan 15, 2019
250
87
Leeds
I think it was a faulty sensor, I had a look in VCDS and all the coding was correct so I swapped the sensor for a new one and it doesn’t do it anymore.
