Error Address 52
Jun 28, 2021
Good day.
Today I can't pull down the passenger window at once, but in steps of 6X, always just a short distance away and return the same. I had these errors in VCDS. Can you please advise me what is wrong and where to check?
Thank you very much....
Address 52: El. PP Door Labels: SVO \ 5QX-959-X92-52.CLB
Order number of the control unit: 5Q4 959 592 HW: 5Q4 959 592
System and / or version: TSG BFS 007 0006
Coding: 001C032CD000020000001000
Workshop number: WSC 00049 770 00195
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001 (SE37)
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 015E70532184FD235DC-8054
3 faults found.
65639 - Glass starter motor
B1487 29 [009] - Wrong signal
Confirmed - Tested since the memory was cleared
fault information:
Defect condition: 00000001
Priority of faults: 3
Frequency of faults: 1
Reset counter: 221
Mileage: 226401 km
Date: 2021.07.12
Time: 16:38:08
65588 - Glass starter motor
B1487 54 - Missing calibration
Sporadic - Confirmed - Tested since the memory was cleared
fault information:
Reset counter: 6
Mileage: 226401 km
Date: 2021.07.12
Time: 16:37:08
65604 - Door open light
B1326 01 [009] - Electrical error
fault information:
Reset counter: 221
Mileage: 226401 km
Date: 2021.07.12
Time: 16:36:51
adam davies
338
138
Id start by swapping the door control module 5Q4 959 592 from the left door to the right door, id assume they are interchangable. Then see if the fault moves to the opposite door if it does you have found the problem. I would also check window regulator mechanism by taking it out and making sure it runs smoothly with no obstructions.
Reactions: berki
Jun 28, 2021
Hello friends, thank you very much for trying to help. adam davies, UnworthyBean.....
So I solved everything .... :)
I coded the tilt of the mirror when reverse gear was engaged and instead of BIT 4 and checked bytes 2 and 3, I checked the bytes in BIT 3.
Fixed and everything is OK and great.
Thank you for your time
Reactions: adam davies
adam davies
338
138
No probz didnt know youd been messing with coding lol. 👍😆
Reactions: berki
