Coolant temperature going down when driving
Jan 15, 2024
Hi,
I have 2019 Seat Leon Se Dynamic Tsi Evo and it takes a long time for the engine coolant to warm up (around 15 minutes when stationary). However, once it reaches around 80/90 degrees it drops back down to 50 degrees when driving.
I am suspecting the issue being with the thermostat, however when looking for thermostats for my vehicle I cannot find any compatible.
Anybody have any recommendations or have had this issue in the past?
BillyCool
655
249
Leicestershire, UK
Hi,
Could be the thermostat misbehaving/sticking. Not sure if you have the electronic switchable water pump on your car. They can play up as well.
Have you put your reg in here: https://www.autodoc.co.uk/
You must be able to find an OEM part number and find what you need somewhere.
Jan 15, 2024
Hi
Thanks for the reply, i put my number plate in the website you provided but still it says there are 0 results for thermostats for my car. I guess ill have to find the OEM part number. I just find it weird that no results come up for a thermostat for my vehicle and wondering if my vehicle even has one lol.
redone
63
23
ebay or amazon have ‘check compatibility with your car’ functions where the results are supposed to fit?
LeylandVCDS
287
154
Leyland, Lancashire
Unfortunately I've found the ebay compatibility checker very, very inaccurate. Far safer in these cases to go to the dealer - at least if the wrong one is supplied there is a comeback
