Toyosport 600, 300, 76mm FMIC fitting guild. Also known as the Wellycooer.
Nutta121
151
Hampshire
Ok I so il need all pipes you mentioned apart from the joiner then, to make it work? Also how did you sorce the top mounting plates
Seal_LCR
2,601
Redditch
Yeah that's right. I'm gonna sort so silicone for the TB aswell as ill show you when I get pics in abit.
I got some angle from work and cut,drilled it myself.
ReDBull
Every day's a school day.
Nov 21, 2006
2,991
13
Lincoln
You'll love it when you've fitted it!
Re the badge it's two pieces plastic one trimmed to R badge shape. A nut and counter sunk bolt long enough to go through the grill. Drill a hole in each piece of plastic, pass the bolt through the R badge side then through the grill. Position the othe peice of plastic the other side of the grill with the nut. Tighten it up and stick the R badge to it.
Richard123
Rickys LCR 225
Feb 4, 2013
169
Ayrshire,Scotland
Thanks Im shure I will.
only half the pipes arrived today, so not be doin it this weekend unfortunatly.
I dont suppose u have a few photos of installing badge just to make it as little bit clearer?
how did u trim plastic to r badge shape?
thanks again Richard
george20vt
thats very neat! i used a grinder to cut alot of the inside of my bumper out on my mk1 for it to fit
