So I've got a 20 plate Ateca Xcellence Lux with blind spot monitoring and KESSY. I've been having issues over the last few months with both. It has been into the local dealership who basically said it was dirty sensors (blind spot monitor) and keyfob battery for faulty key (KESSY).
1. Blind Spot issue - I basically get the drivers side blind spot indicator coming on randomly when driving (empty roads no nearby vehicles). Typically for periods for 30 secs to 2 mins. I've cleaned the sensors and check them regularly for debris. Nothing. Still doing it though. Technician did mutter something about low voltage levels but did not elaborate. My question is if it's doing it ONLY on the driver's side how can it be debris. Surely I'd be seeing the issue on both sides if they were equally dirty.
2. KESSY. I'm getting repeated issues with between the car and key. Often I will get out of the car and then the central locking will engage the second or two after a door is closed. (not the normal lock sequence as the mirrors do not fold in). Touching the door handles has no effect and the key must be used to unlock the car. This happens a lot. The dealer thought my worn main use key was the issue and fitted a new battery (even though I'd fitted one 1 week earlier). I've now switched over to a brand new unused spare key (no wear at all) with brand new battery and the issue still persists. I also often have to present the key to the special spot on the steering column for it to work (new key, new battery). So to me clearly something is failing here. I am always worried one day I'll forget to take the key on exit and be locked out of the car!
My guess is that the modules have developed some fault but the dealership are trying to eek it out until my warranty expires. Luckily I've just extended mine for another 12 months with Seat (as I was at the end of my 3 years in June).
Just wondering if these were common issues with a known remedy as the dealership seems clueless. I know there are modules into which the body blind spot/parking sensors are connected (inside the wheel arches). I am wondering if one of these has developed a fault.
As the the KESSY I've no idea what device does the comms between the key and the car but I guess something must be causing the issue.
Any advice/solutions welcome.
thanks
Ad.
thanks
Ad.
