coil packs expensive to fix mate? I heard could also be spark plugsCould also be coil packs.
The Fault code's are
005445-throttle valve controller p1545-001-malfunction-intermittent
005476-throttle actuator (j338) p1564-002-under-voltage during basic setting-intermittent
U can clear both these codes and they re apear apon the ignition being turned on without the car being started��
All codes have been taken Via vag com
I had the same codes on my Leon, Latest REVISION Throttle Body swapped and problems went away!
the car has a new one fitted but im unsure the part number as i never fitted it
