Badger5
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum » Leon » Leon Mk2
Leon Mk2 For all topics relating to the Mk2 Leon
Reply
Thread Tools Rate Thread Display Modes
Old 08-02-2018, 16:10   #1
Mhug
Mhug has 10 points
Leon fr tdi 2008 hesitates when accelerating
Hello guys new here but have been a lurker for a while.
I've just bought a 58 plate fr 170 and had it about a month now. When accelerating I get a hesitation from 3rd gear and every gear after where I try and put my foot down. More noticeably in 5th and 6th up to around 2500 revs the car vibrates when accelerating. Does anyone know what might cause this? I'm no mechanic so I guess I'm just curious what issues it could be and how much it would cost to fix.
Mhug is offline   Reply With Quote
Old 08-02-2018, 21:31   #2
DavieTDI
Brain dead
DavieTDI has 10 points
Sticking veins, boost leak, dirty fuel filter. Get it plugged in and see whatís going on.
DavieTDI is offline   Reply With Quote
Old 08-02-2018, 21:43   #3
Mhug
Mhug has 10 points
Thanks, so what you're say is it could be lots of different things? Do you know any where local to Manchester that will have a look without charging me an arm and a leg?
Old 09-02-2018, 07:06   #4
DavieTDI
Brain dead
Am not sure when could in that area, but if your not sure when it was last serviced then I would do that first with the fuel filter and see if that does the trick.
Old 09-02-2018, 12:22   #5
Legojon
Senior Member
Legojon has 10 points
Have read good things about AwesomeGTI. They're Manchester way. Can't say what their prices are like, but at least you'll get a decent service.
__________________
Seat Leon Cupra R 2011 (revo I) http://www.seatcupra.net/forums/showthread.php?t=435417
Seat Leon FR+ 2012 (revo I) http://www.seatcupra.net/forums/showthread.php?t=421491
Legojon is offline   Reply With Quote
Old 09-02-2018, 13:40   #6
Mhug
Mhug has 10 points
Perfect, thanks for the info 😊
Old 10-02-2018, 10:57   #7
Mhug
Mhug has 10 points
I'm going to get booked in for a full service with Awesome GTI. Ive just enquired about a full service so hopefully nothing too serious will come of it. Thanks again for the advice
Old 10-02-2018, 12:09   #8
Lorand02
Lorand02 has 10 points
Had exactly the same problem, someone told me to change the fuel filter, no diference hesitation still there, rebuild turbo hesitation gone
Lorand02 is offline   Reply With Quote
Old 10-02-2018, 14:13   #9
Mhug
Mhug has 10 points
Was yours constantly lagging or intermittently? Mine can be okay one minute then really bad the next with no consistency...
Also how much did the reconditioning set you back? I'm reluctant to pay too much as I only bought it last month from a small dealer. I paid £4500 with only 80000 miles on the clock.... Got 6 months warranty but I've heard that they aren't worth the paper they're printed on
Old 10-02-2018, 14:40   #10
Lorand02
Could be the egr valve, when i bought the car it did hesitate a lot, only after a half hour of driving the hesitation was gone, but still came back on high rpm randomly, I took down the egr valve and throttle body and cleaned up everything over there, the hesitation on cold was gone, the one on high rpm was coming in randomly only in higher gears, when I made a remap on the car a guy over there took it for a test drive and he told me the hesitation is from the fuel filter, after changing the filter the problem was still there. A while back I was thinking to rebuild the turbo becouse I could see oil on the pipes behind the engine and it was coming from the turbo sealing and the turbo was whistling like a jet engine, I rebuild the turbo 2-3 weeks ago no hesitation problems till now. £600 was the rebuild.
Old 10-02-2018, 14:46   #11
Mhug
Mhug has 10 points
Perfect, Do you reckon if I take mine in for a service they will be able to diagnose what's going on? Sorry if I sound like a noob...
Old 10-02-2018, 15:02   #12
Lorand02
I was at seat I stayed 3 hours, after 3 hours they said everything its OK. So I scratch my head and drive away, they say something about maybe egr, I told them I cleaned the egr, they say buy a new one I say whatever, then they said something about Injectors. When I did the remap on the car one guy over there told me that if I had problems with the Injectors the engine will knock badly and on tester the Injectors where working as they should. The hesitation on cold was from the egr valve but now the valve is deleted. Try to go to a tuning garage and ask them what do they think about the turbo. Does your car smoke?
Old 10-02-2018, 15:54   #13
Mhug
Mhug has 10 points
Yeah sometimes, Especially when cold or putting my foot down
Old 10-02-2018, 15:55   #14
Mhug
Mhug has 10 points
To be honest I don't know if the DPF has been deleted or not. As I say I'm no mechanic.
Old 10-02-2018, 16:06   #15
Lorand02
Mine was smoking before the remap, white smoke and it was puffing, like choking on cold. After remap engine smooth on idle and no smoke anymore, it smokes only when it's about 0 degrees outside, for like 5 min till it warms up. Mine was smoking on idle, when the car was moving and engine 90 degrees it was OK, but when I stopped at a street light or something it smoked, after a lot of driving the smoke eventually went away, but slowly came back when the car wasn't moving.
Old 10-02-2018, 16:09   #16
Lorand02
Mine has the dpf removed and doesn't smoke a bit after remap
Old 10-02-2018, 20:59   #17
DavieTDI
Brain dead
Start with cheap option. Tell them what is going on and they will have a look. Donít jump straight into blaming the expensive parts right away. Itís all good people telling you what was wrong with the car they had. But this is your car.
With me it was fuel filter that was black and starving the car of fuel at high revs. It can be a number of things so always best to get it plugged in and look at the numbers.
Old 11-02-2018, 21:50   #18
Mhug
Mhug has 10 points
Buzzin thanks for the tip davie ☺
Old 13-02-2018, 14:21   #19
Mhug
Mhug has 10 points
Have any of you guys seen these engie things? It's a Bluetooth OBD that hooks up with your phone?
Old 16-02-2018, 19:03   #20
Mhug
Mhug has 10 points
Done the fuel filter.... No different
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 18
Asce, Fishy, Hawkers, heggie, Jay sx, jonnybravo, Legojon, Lloydy89, Lorand02, Mhug, niallain, Pdog, Rusty2k, steve7786, STi69, t121anf, tickerz, Wenny123
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
