im confused about tyre pressure's, help plz :(
splatrat
123
stoke on trent
i have 19 inch wheels on a 2007 tdi fr and am really confused as to what my tyre pressures should be .............can anyone help?
sorry the tyre size is 235/35/19
Feb 12, 2006
625
North Lincolnshire.
35psi all round would eventually wear the middles out same as 30psi all round will eventually wear out the edges of the fronts a bit but near enough ok for the rears.Best off sticking to the correct spec: which is 29psi rear and 32psi front with normal load,unless you drive all over with 4 passengers and/or a large load in the boot. Give or take the odd psi. NEVER EXCEED 32 or 33 psi EVER or buy new tyres sooner.
leon_lib
seat leon FTW
Dec 22, 2008
216
burnley
but with a different size tyre in my case being larger wouldnt the new tyre need more psi to fill as the older was smaller or am i just being thick?
