1.4 ecotsi 150 - 5w40 oil?
MA1601
31
10
Hi all
I’ve always used 5W-40 oil in my previous VW/Audi Tfsi/tsi cars as I do mainly short journeys and town driving so change oil every 12 months. Not sure what’s the case now but it was the recommended oil grade for short drain (1 year) intervals. So is it OK to use it in my 1.4 ecotsi engine code CZEA? Everywhere online says 5w-30 so I’m wondering if 40 would be too thick for these newer tsi engines. Thanks
oldgitdave
508
239
UK
It won't do any harm but may very slightly reduce your mpg. The best advice is to use oils that are recommended in the manual tbh.
Reactions: Mr Pig
andylong
490
I don't know if it does any harm but a thicker oil will flow less easily and in cars with oil pressure control reduce flow, oil pressure rises with thicker oils through the same restrictions etc.
Engines are designed with certain oil thicknesses in mind and there's a trend towards thinner oils nowadays
SuperV8
1,345
595
Your manual confirms the oil spec required for your car.
There are variations depending on year, time/distance - or longlife.
Pick an oil with the correct VW approval. (not just recommendation)
For the CZEA which has ACT looks like VW504 if on time dependent servicing.
VW502 is 5w-40
VW504 is 5w-30
VW508 is 0w-20
example from 2017 manual:
MA1601
31
10
Interesting stuff. Manual says
VW502 is 5w-40
VW504 is 5w-30
VW508 is 0w-20
Interesting stuff. Looks like it was changed for the facelift (presumably for emissions reasons). Mine is a 2016 pre-facelift and the manual says:
andylong
490
Thinner oil is good, it still lubricates and gets to where it needs to be faster. This is particularly important while the engine warms.
Reactions: MA1601
MA1601
31
10
I used to own a 1.4 tfsi Audi A3 (8p generation) which consumed a bit of oil on 5w-30 but none on -40. Since then I’ve always used -40 especially on my Mk6 gti. Maybe time to switch back to -30!
Mr Pig
2,628
910
Seat have changed their oil from 5w30 to 0w30. I don't know why but either will be fine as long as it ticks the VW 504 00/507 00 box.
Mr Pig
2,628
910
I'm guessing economy again. Less drag etc.
I don't know. Just when I serviced the cars recently the recommended oil was coming up as the 0w30 and I had to google it to see why. I can't see it making much difference to be honest.
andylong
490
I read somewhere, a paper on oil modifiers, that the base oils are different to offer low low temp viscosities and that modifiers allow that base to operate at the higher temps. So the oil will always be runnier (sciencey huh?) But behave like it has a higher viscosity so maybe the oil will offer less drag etc, over the whole temperature range, while still resisting the shear forces for example.
As to making a difference, it's likely one of a range of measures, tyres, oil, start stop, cylinder cut out, engine map, fuelling etc etc that each contribute to the really efficient engines we have now.
