2021 Arona FR headlight range
AlR
27
Is it possible to check/adjust the led headlight range with VCDS? Mine seems to be set so low and the cutoff so severe, that I just can't se far enough ahead to go faster than 40 mph. I'm sure the dealer will be happy to charge me to tell me they are at factory settings.
Tell
Suggest you tell your dealer it is incorrectly set up and get them to adjust.
The LEDs are suppose to be self levelling which is why you see them move at start-up. Least Ateca does. I'm sure the Arona the same. Sensors. Then there is suppose to be an adjustment on each headlight that people fiddle with, with marks on garage walls etc. I'd claim it as incorrectly set up at delivery and get a dealer to do it on their test equipment.
Reactions: JoseKaLeL
