Charging minimum and departure settings
Jan 23, 2022
7
Aargh.. such a peeve with this..
So, I have a weekday morning schedule (7am)
If I plug in after a drive on the weekend , I’ll either get the short abrupt green flashes ( planned charge related to departure the coming Monday ) .. or the slow pulsing green charge indicator.
but..
the problem is I want to charge immediately, without the minimum charge set ( has been on 50% to get the most possible)
I put the car to charge Saturday afternoon, no off peak time is set.
The car began the rapid blip.. my thoughts were it’s waiting for the Monday departure.. so I had to unlock the car, get in and cycle ignition.. to get the e-manager open.. then press ‘ start charging’
I could see this starting the charge, the pulsing green indicator was active.
However this morning only 50% was charged… aargh
I’ve now set the minimum down to 0
But when I put it to charge this afternoon it went directly into rapid blips.. as no minimum was set. Ffs
so back in the car and start the charge manually again…
am I missing some obvious function setting somewhere?
I just don’t get why if I have a departure schedule set, it would make any difference on the weekends?
hope someone has experienced something similar and is able to shed some light :)
regards
Andy
irfy8
164
29
If you dont have the off peak tariff then just set the temp for dep not the charging.
Stebb
155
23
60
Machynlleth
You can set the off-peak marker (in the app anyway) differently per departure time. So my car is set to charge every night off-peak (clearly it won't charge if already full). If I have a separate journey to make I add a departure time without the off-peak marker.
Alternatively, when I power off the car after a trip, it offers Charge Immediately before I open the drivers door. I can then plug it in and it starts straight away.
I didn't think the minimum charge setting was for when you plug in - only for when you're driving?
Feb 25, 2022
Hello all, first time poster, apologies for hijacking the thread...
I picked up my Leon ehybrid yesterday, it's the first charge tonight and struggling with scheduled charging.
I'm on an E7 tariff so I've input the off peak times into e-manager. Despite this it just wants to charge straight away. I've also tried to force it another way by setting the departure time to 6.55am, the same time as my night rate finishes to see if that works and still an instant charge.
I've given up for tonight and just left it charging on the day rate, any ideas what I'm doing wrong? I can only think with all the trying and changing settings I should have done things in a certain order.
The car is great by the way, really looking forward to many miles in it.
Joe
irfy8
164
29
Joe
Check the minimum charge and set that to 0.
Feb 25, 2022
Cheers irfy8
I've updated to 0 and hopefully that does the trick when I next charge.
Not sure if it's me but that setting isn't in the most logical of places, tucked next to the hybrid mode button. Oh well, at least it's sorted.
It seems I picked the car up at the perfect time, the petrol stations are starting to run dry again in my area!
Thanks once again
