Cruise control/speed limiter not working.
Mar 18, 2024
Hi all.
I took delivery of my Formentor 1.5 v2 at the weekend, however….
I just can’t get the cruise control or speed limiter to work, even above 20 mph. Whenever I select the option on the steering wheel it pops up ‘Acc deactivated’
it’s doing my head in now. Can anyone help please? Thanks.
Villabrand
85
30
You should have a button on the steering wheel to turn it on, as per the picture. Click that first and ACC is activated, can then hit set to set the current speed. +/- then increases to the nearest 5 mph ie. 40-45-50 etc. using set/Res increases by 1mph in either direction.
If you turn on ACC should be on automatically next time you start the car. Whilst using ACC if you hit the active/deactivated button it cancels the current set speed. Press again to deactivate ACC completely.
Sent from my DN2103 using Tapatalk
