Glow Plugs for a Leon Cupra TDi 2004
Foz
OK so VAG-COM is reporting a faulty glow plug and I'm looking to get a replacement, following is the part number from a current one.
BOSCH - N 105 792 01
Looking on vwspares there seems to be two BERU version that fit the Leon.
GN855 and GN046 (The GN046 seem to the be correct one)
I've been looking around and found some people post having issue with the GN046 plugs being slightly longer and that they've used the GN885 instead. (on the "17058 Glow plug problem" thread.)
Does anyone know what version should be used and if the longer ones would do any damage? Seems strange that the OEM part would be any longer.
Thought this was going to be an easy job.. now I'm not sure.
Chris.
Jan 22, 2007
2,074
some may say lala land....
no idea about size issues - i used what was in the tdi thread i supplied and got garage to do
i did harness as that went as predicted in similar thread approx 3mnonths later
do all 4 as it can say that 1 is out and mean 3
easier, cheaper and why do the job again if can do it once for all
Foz
Cheers, will give me piece of mind.. ;-)
The cars been starting fine so not really in a hurry, I suppose the warmer weather must help.
Jan 22, 2007
2,074
ok Foz,
This is what i have bought to fix that error code:
038971220D - n/stk 051275/bridge 19.64 +VAT each - need x1
AN10579202 - n/stk 043771/glow plug 12.35+VAT each - need x4
neilw
Foz
This seems to be the OEM parts that match the ones from your order.
http://www.vwspares.co.uk/product_info.php?products_id=56
But I'm still not sure so should I just get them from the dealer. Checked with them today, seems to be the same price as you've quoted which will cost slighlty more than online, suppose I know they must be correct ones atleast.
Did you just buy from the dealer?
cupra87
hi guys
is the harness easy to replace?
as seems to be the issue, mine has gone aswell
thanks
