Hi I've got an 06 plate ibiza FR tdi. I've read about swapping the air inlet tube and fitting a panel filter. Is this easy and worthwile? An does anyone know where you can get front top strut brace or does the cupra one fit?? Ta
I am going to the do the "flap mode". But with the intake part which screws onto the front bulk head, The air seems to be restrictive. Can you just take that part off and cable tie it onto the bulk head, that way the intake gets better air to it?.
Not a clue mate but this may help I took the air box apart and took the body of the m.a.f off and where the sensor is there is like a plastic plate with squers pressed frew it which is in frount of the sensor like its protecting it which looks like would restrict air flow I have removed the dust flap on the front and the round spigot in the top of the box just can't find the criss cross bits to remove any help
I think you mean the mesh in front of the MAF, called de screening the MAF, many people have discussed this before on here, have a search through, some people have removed, others say its to help smooth the airflow. The difference is negligable anyway.
is there anywhere you can get the pd160 intake pipes other than seat direct..? 85 quid or however much they are is a bit ridiculous for a 10 inch long plastic tube. a guy i spoke to said they used to be about 25 quid before they clicked on other people wanted them.
